how to display full year calendar in teechart/reportbuilder
kam
Post by kam » Wed Sep 24, 2014 1:48 pm
Hello
I have teechart pro 2014 and reportbuilder 15.04
I wish to display a full year calendar on the report. (not just one month but all 12 months)
how can this be achieved ?
kam
Re: how to display full year calendar in teechart/reportbuilder
Post by Yeray » Thu Sep 25, 2014 7:31 am
Hello kam,
I see two alternatives you could give a try:
- 12 TChart in the same form/report, each chart showing a month.
- 1 TChart with a TSubChartTool and 12 TSubCharts in the tool, each subchart showing a month.
kam
Post by kam » Mon Sep 29, 2014 11:37 pm
Thanks for suggestions:
It is not clear to me however how to assign the values to the calendars.
eg if i have 12 calendars on a page
calendar 1 should be set to january 2014
calendar 2 should be set to february 2014
etc. etc.
some sample code would be helpful
kind regards
Kam
Post by Yeray » Tue Sep 30, 2014 11:11 am
Hi Kam,
Here it is a simple example:
uses TeeCalendar;
var Calendars: array[0..11] of TChart;
var i: Integer;
  Caption:='2014 Calendar';
  for i:=0 to 11 do
    Calendars[i]:=TChart.Create(Self);
    Calendars[i].Parent:=Self;
    Calendars[i].Width:=200;
    Calendars[i].Height:=200;
    Calendars[i].Left:=(i mod 3)*Calendars[i].Width;
    Calendars[i].Top:=(i div 3)*Calendars[i].Height;
    with (Calendars[i].AddSeries(TCalendarSeries) as TCalendarSeries) do
      Date:=StrToDate('1/' + IntToStr(i+1) + '/2014');
      NextMonthButton.Visible:=false;
      PreviousMonthButton.Visible:=false;
      Trailing.Visible:=false;
      Today.Visible:=false;
