Pattern per point
Jim Green
Pattern per point
Post by Jim Green » Mon Jun 01, 2015 5:43 pm
Hi, I need to show a pattern whose color is different for each point. Can this be done?
Jim Green
Re: Pattern per point
Post by Jim Green » Mon Jun 01, 2015 5:44 pm
PS. I should have said that this is a Bar series.
Post by Marc » Tue Jun 09, 2015 9:22 am
One approach could be to set the Bar's render style as image.
for example (taken from TeeChart's demos\series\bar\bar.htm example):
Chart1.series.items[0].format.image.url="../../images/diag.png";
Here I have changed the default .jpg image to a .png image that supports transparency (optional possibility) and where the .png image represents a pattern.
Post by Marc » Thu Jun 11, 2015 10:47 am
As a followup on this point, pattern repeat has just been added to the image fill style for BarSeries to permit homogenous pattern repeat/tile across different bar sizes.
Jim Green
Post by Jim Green » Thu Jun 11, 2015 10:05 pm
Marc, I am using an image (that's what I meant by pattern). What I need is a different pattern per-point. E.g. a red hatch for one point and a blue hatch for another.
I am already controlling color per-point. Are you saying that I can use one pattern for series 1 and another pattern for series 2, and each point's color will show through at the png's transparent areas? If so, that's exactly what I need (one pattern per series but colored per point).
Thanks, Jim
Post by Marc » Fri Jun 12, 2015 10:34 am
Hello Jim,
I hadn't thought of it in that way, to provide the point colour as background to the transparent pattern. Default behaviour would be to show transparency through to the chart background.
But I've modified the TeeChart code to offer the option you describe and have emailed you the test file with example. We'll incorporate the change into the next update release.
Jim Green
Post by Jim Green » Fri Jun 12, 2015 7:29 pm
Marc, this works perfectly. Thanks so much!
Jim
