Labels for MultiBar=mbSideAll on all Series
Graham
Post by Graham » Wed Sep 30, 2015 1:16 am
I saw a reference to this wish list entry in the VCL forum: TV52014973 under a 2009 post with subject: "Side All, Labels on Axis X".
It relates to putting X-Axis labels on all columns of a bar chart when MultiBar= 4 i.e. mbSideAll in cases where you have more then one series. Some code was proposed, seebelow, but I cannot get it to work.
  tmpPos:=0;
  DBChart.Axes.Bottom.Items.Clear;
  for i:=0 to DBChart.SeriesCount-1 do
    for j:=0 to DBChart[i].Count-1 do
      DBChart.Axes.Bottom.Items.Add(tmpPos,DBChart[i].Labels.Labels[j]);
      Inc(tmpPos);
I am using TeeChart AX 15.0.0.2, on Win8.1(64) with dBase, so I have to convert the code, but even then certain methods do not exist.
Graham
Re: Labels for MultiBar=mbSideAll on all Series
Post by Yeray » Fri Oct 02, 2015 11:28 am
Graham wrote:I saw a reference to this wish list entry in the VCL forum: TV52014973 under a 2009 post with subject: "Side All, Labels on Axis X".
Yes, here it is.
Graham wrote:It relates to putting X-Axis labels on all columns of a bar chart when MultiBar= 4 i.e. mbSideAll in cases where you have more then one series. Some code was proposed, seebelow, but I cannot get it to work.
That was an example in Delphi for TeeChart VCL/FMX; in ActiveX some properties/functions may be a bit different.
This works fine for me in VB6:
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scBar
  Dim i, j As Integer
  For i = 0 To TChart1.SeriesCount - 1
    TChart1.Series(i).FillSampleValues 4
    For j = 0 To TChart1.Series(i).Count - 1
      TChart1.Series(i).PointLabel(j) = "Series " + Str$(i) + ", Point " + Str$(j)
    Next j
  Next i
  TChart1.Series(0).asBar.MultiBar = mbSideAll
  TChart1.Axis.Bottom.Labels.Angle = 90
  Dim tmpPos As Integer
  tmpPos = 0
  TChart1.Axis.Bottom.Labels.Clear
      TChart1.Axis.Bottom.Labels.Add tmpPos, TChart1.Series(i).PointLabel(j)
      tmpPos = tmpPos + 1
    Next j
  Next i
Graham
Post by Graham » Sun Oct 04, 2015 8:30 pm
Many thanks, that is a great help.
Graham
