TPolarSeries - inverting the series / chart rotation
ChristianZ
Post by ChristianZ » Mon Oct 26, 2015 7:29 am
Dear all,
I am currently using TPolarSeries (8 pieces) to display 360° circled measurements.
Depending on the customers selection, I'd like to display the circle in clockwise or ccw direction.
Unfortunately I did not find any way to full fill this. I indeed can change the labelling to cw / ccw but not the measurements themselves.
Any idea what to do ?
Best regards
Christian
Re: TPolarSeries - inverting the series / chart rotation
Post by Yeray » Tue Oct 27, 2015 3:44 pm
Hello Christian,
I see the fix for 763 was causing this.
I've revised it so it will be okay with the next maintenance release.
Since you own the sources, I'll send you the modified TeePolar.pas unit so you can replace it and run TeeRecompile to install it into your IDE.
