Custom mark position
Eic
Post by Eic » Fri Apr 22, 2016 7:57 am
I started in the use of TChart. I want to customize the position of the marks.
One solution is described here: http://www.teechart.net/support/viewtop ... on+lefttop.
But in my case Series-> Marks->Positions->Count is 0 on AfterDrawValues event.
Le comportement a-t-il changé depuis la publication du post pré-cité ?
Re: Custom mark position
Post by Yeray » Fri Apr 22, 2016 10:23 am
Bonjour,
I've tested this adding a TBarSeries to a new empty chart at design time; I've also added sample values to it.
Then I've implemented this simple OnAfterDraw event and it seems to work fine for me:
void __fastcall TForm1::Chart1AfterDraw(TObject *Sender)
  Caption=Series1->Marks->Positions->Count;
Eic
Post by Eic » Fri Apr 22, 2016 11:59 am
The other post was talking about Series->OnAfterDrawValues event.
This works in the event Chart->OnAfterDraw.
My problem is solved, thank you.
Post by Yeray » Fri Apr 22, 2016 2:42 pm
Eic wrote:The other post was talking about Series->OnAfterDrawValues event.
Sorry, I misread it.
Forcing a Chart repaint at OnCreate solves the problem with calling Series1->Marks->Positions->Count at OnAfterDrawValues event. Ie:
  Chart1->Draw();
