How to create a multiline legend entry
Rolf Fankhauser
Post by Rolf Fankhauser » Thu Dec 16, 2004 2:11 pm
I have a chart with long legend entries. Therefore the width of the chart is smaller than the legend. I would like to keep the legend on the right side of the chart. How can I split the legend entries to two lines? I created the text of the entries during run-time.
Kind regards,
Rolf
Marjan
Post by Marjan » Thu Dec 16, 2004 4:03 pm
Hi, Rolf.
This feature is not yet supported. You'll have to use chart OnGetLegend** events to customize individual legend item position and text. There are some examples about customizing legend items available in TeeChart demo.
Marjan Slatinek,
Rolf Fankhauser
Post by Rolf Fankhauser » Fri Dec 17, 2004 10:36 am
Hi Marjan,
I didn't find an example with multiline legend entries. My wish is to automate the multiline option: if the string for the legend entry contains a line break it should automatically generate two lines. The only way I see is to use OnGetLegendText:
- Check if there is a line break in the legend entry
- If yes then
1.solution: Increase the space between the entries (Is it only possible for all spaces , not for individual between two entries?) and write the rest of the string in the space (how to do that?).
2.solution: Make additional entries and write the text there. But is it possible to make entries without series? Do I have to create empty series to have additional legend entries? I use checkboxes. Is it possible to hide the checkboxes and legend symbol for some entries?
Maybe you know another, better workaround?
Kind regards,
Rolf
Post by Pep » Fri Dec 17, 2004 12:14 pm
Hi Rolf,
the best workaround I can think of, is the custom drawing on the Legend. There's an example in the Demo Features project under All Features -> Welcome ! -> Miscellaneous -> Legend -> Drawing more text
