Problem with OnGetAxisLabel event
lolo1988
Post by lolo1988 » Thu Aug 17, 2017 11:58 am
I've got an issue when using the OnGetAxisLabel.
I've got a couple of TLineSeries, created at runtime, with ParentChart assigned to Chart1 for instance.
Those Series are drawn correctly in Chart1.
But when the Chart1.OnGetAxisLabel(Sender : TChartAxis; Series: TChartSeries; ValueIndex: integer; var LabelText: string) events occur, Series is not assigned and ValueIndex is always equal to -1, whatever the actual position of LabelText.
I want to custom the new LabelText with Series.XValues and ValueIndex, but I failed in connecting the runtime series with the actual Chart axis...
Thanks for any help,
Laurent
- Delphi6 / Teechart 7.04 -
Re: Problem with OnGetAxisLabel event
Post by Sandra » Fri Aug 18, 2017 3:32 pm
Hello Laurent,
Maybe the problem is caused because you need set the LabelStyle as Text. The code below works fine for me using latest TeeChart Pro 707:
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
  Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
if valueIndex>-1 then
Caption:= 'ValueInex'+ FloatToStr(valueIndex); //Change that for your code.
Series1.FillSampleValues(10);
Chart1.Axes.Bottom.LabelStyle := talText;
Hoping this helps you.
Thanks in advance
lolo1988
Post by lolo1988 » Mon Aug 21, 2017 10:14 am
Hello Sandra,
Thank you for your reply.
Actually, my problem came from the fact that the "Series" parameter of the event is not assigned when the event occurs. So calling properties of this local parameter failed.
I solve my problem by using the global Chart1.Series parameter instead of the local 'Series' parameter of the event.
But I'm interested in having information about how the "series" local parameter of the OnGetAxisLabel event works and how it is fed when several series share the same axis?
Thank you again for your help,
Laurent
Post by Yeray » Tue Aug 22, 2017 7:31 am
Hello Laurent,
lolo1988 wrote:But I'm interested in having information about how the "series" local parameter of the OnGetAxisLabel event works and how it is fed when several series share the same axis?
The OnGetAxisLabel event should be fired with an assigned Series parameter when there are labels in that series and the Axis LabelStyle property is set to talAuto, talText or talMark.
