Tab movement suppresion in edit mode
ghanshaw
Post by ghanshaw » Fri Jan 12, 2018 6:22 pm
Is there an easy way to suppress the movement from the tab key when in edit mode like there is for the enter key?
I have tried using FormKeyDown logic but it seems to work only every other time the tab key is pressed.
ghanshaw
Re: Tab movement suppresion in edit mode
Post by ghanshaw » Thu Jan 18, 2018 12:04 pm
I have managed to disable the tab movement but have now noticed that use of the arrow keys does not generate any events. How can I track which cell of the grid the user has arrowed to?
Post by Yeray » Mon Jan 22, 2018 8:58 am
I've been able to fire an event when the TAB key is pressed while editing a cell. The problem is the IEditor control in TVCLTeeGrid is "private" and to use it we will have to move it to "protected":
    procedure CMDialogKey(Var Msg: TWMKey); message CM_DIALOGKEY;
type TVCLTeeGridAccess=class(TVCLTeeGrid);
procedure TFormGridDataset.CMDialogKey(Var Msg: TWMKEY);
  if (Msg.CharCode = VK_TAB) and (ActiveControl = TVCLTeeGridAccess(TeeGrid1.Grid).IEditor) then
     ShowMessage('TAB key pressed');
  inherited;
