Creating a Trend Line series at run-time
Markus46
Post by Markus46 » Wed Nov 07, 2018 10:48 pm
I have an existing TChart object "LChart". It's a component on a form.
I have an existing TChartSeries "LSeries". It's created at runtime based on a series type string "LSeriesType" like so:
  C : TRttiContext;
  T : TRttiInstanceType;
  V : TValue;
  LSeries: TChartSeries;
    C := TRttiContext.Create;
    try
      T := (C.FindType('VCLTee.Series.'+LSeriesType) as TRttiInstanceType);
      if assigned(T) then begin
        V := T.GetMethod('Create').Invoke(T.metaClassType,[Visualisation]);
        LSeries := V.AsObject as TChartSeries;
      end
        raise Exception.Create(format('Could not create %s graph type', ['VCLTee.Series.'+LSeriesType]));
    finally
      C.Free;
    LChart.AddSeries(LSeries);
initialization
  // Reference every series type so that they get linked into the exe and can be found at runtime by TRttiContext.FindType
  TBarSeries.ClassName;
  TAreaSeries.ClassName;
  TFastLineSeries.ClassName;
  THorizAreaSeries.ClassName;
  THorizBarSeries.ClassName;
  THorizLineSeries.ClassName;
  TLineSeries.ClassName;
  TPieSeries.ClassName;
  TPointSeries.ClassName;
This code works and the chart displays OK.
Now I want to add a Trend Line series to the chart. I've added this additional code:
  LTrendFunction: TTrendFunction;
  LLineSeries: TLineSeries;
    LTrendFunction := TTrendFunction.Create(LChart);
    LTrendFunction.Period := 3;
    LLineSeries := LChart.AddSeries(TLineSeries) as TLineSeries;
    LLineSeries.SetFunction(LTrendFunction);
    LLineSeries.Color := TColor(fdqVisualisationSeries.FieldByName('TrendLineColor').AsInteger);
    LLineSeries.Title := 'Trend';
    LLineSeries.DataSource := LSeries;    // LSeries has no data at this point
    LLineSeries.XValues.Name := LSeries.XValues.Name;
    LLineSeries.XValues.Order := LSeries.XValues.Order;
    LLineSeries.YValues.Name := LSeries.YValues.Name;
    LLineSeries.YValues.Order := LSeries.YValues.Order;
LSeries data points are added after the above code.
I am not seeing the Trend Line series displayed at all.
Can you please let me know what I might be doing wrong here?
Many thanks
Mark
Re: Creating a Trend Line series at run-time
Post by Yeray » Thu Nov 08, 2018 11:09 am
Hello Mark,
Try calling CheckDataSource on the LLineSeries to force it to retrieve the new values:
  LLineSeries.CheckDataSource;
Markus46
Post by Markus46 » Thu Nov 08, 2018 8:22 pm
Thanks Yeray!
That line fixes it.
Mark
