dfm Property
tultalk
dfm Property
Post by tultalk » Wed Apr 03, 2019 3:15 pm
Hi:
.dfm shows DefaultCanvas := 'TGDIPlusCanvas';
TChart has no such property as DefaultCanvas but only a DelphiCanvas.
Why doesn't this pop up an error?
Re: dfm Property
Post by Yeray » Thu Apr 04, 2019 8:00 am
There's a private property in TCustomTeePanel named IDefaultCanvas. And at TCustomTeePanel.Create constructor you'll find this to use the value from the registry:
Constructor TCustomTeePanel.Create(AOwner: TComponent);
  inherited;
  // For new charts, set default canvas whatever is at the Registry,
  // or use the class indicated by TeeDefaultCanvas global variable,
  // which is (in VCL) the GDI+ canvas by default.
  // Setting TeeDefaultCanvas:='' will not look at registry, and will not
  // use VCL GDI+
  if (TeeDefaultCanvas<>'') and
     (not (csLoading in ComponentState)) then
     IDefaultCanvas:=TeeReadStringOption('DefaultCanvas',TeeDefaultCanvas)
     IDefaultCanvas:=''; // Existing old charts saved in dfm/fmx, no change
  CreateDefaultCanvas;
Then, to read the DefaultCanvas property from the dfm we use this:
Procedure TCustomTeePanel.DefineProperties(Filer:TFiler);
  function DoWriteDefaultCanvas:Boolean;
    result:=(Filer.Ancestor=nil) or
            (IDefaultCanvas<>TCustomTeePanel(Filer.Ancestor).IDefaultCanvas);
  inherited;
  Filer.DefineProperty('DefaultCanvas',ReadDefaultCanvas,WriteDefaultCanvas,
        {$IFDEF FMX}False{$ELSE}DoWriteDefaultCanvas{$ENDIF});
procedure TCustomTeePanel.ReadDefaultCanvas(Reader: TReader);
  IDefaultCanvas:=Reader.ReadString;
  {$IFDEF FMX}
  IDefaultCanvas:=''; // Switching canvas is not supported yet in FireMonkey
  {$ENDIF}
I hope this explains your doubt.
