OutOfMemory exception with nearly identical Y values (could be related to Bug 2267)
Nathan
Post by Nathan » Thu Feb 06, 2020 5:07 am
These values came up in my application and still cause a crash. I extracted the data from the application and built a simple test project and it still crashs with an out of memory exception.
Series1->AddXY(7217900,282842.7);
Series1->AddXY(7218100,282842.7);
Series1->AddXY(7218300,282842.7);
Series1->AddXY(7218500,282842.7);
Series1->AddXY(7218700,282842.7);
Series1->AddXY(7218900,282842.7);
Series1->AddXY(7219100,282842.7);
Series1->AddXY(7219300,282842.7);
Series1->AddXY(7219500,282842.700000000064);
Series1->AddXY(7219700,282842.700000000064);
Series1->AddXY(7219900,282842.700000000064);
Series1->AddXY(7220100,282842.700000000064);
Series1->AddXY(7220300,282842.700000000064);
Series1->AddXY(7220500,282842.700000000064);
Series1->AddXY(7220700,282842.700000000064);
Re: OutOfMemory exception with nearly identical Y values (could be related to Bug 2267)
Post by Marc » Thu Feb 06, 2020 9:03 am
Yes, this is, I think, related to precision of the double type itself. The problem of a large number with a small fraction.
For example this fails to find a correct Axis increment:
  Series1.AddXY(7219300,282842.700000000032);
  Series1.AddXY(7219500,282842.700000000064);
But this is ok (with the same decimal precision):
  Series1.AddXY(7219300,2842.700000000032);
  Series1.AddXY(7219500,2842.700000000064);
we'll have a think what can help resolve this.
Post by Marc » Thu Feb 06, 2020 9:09 am
There is an interesting solution to the limitation, offered by Yeray for the ActiveX version of TeeChart:
viewtopic.php?f=1&t=17056&p=75804&hilit ... ion#p75804
Nathan
Post by Nathan » Fri Feb 07, 2020 12:44 am
Thanks Marc.
Yes I would appreciate what you can come up with, as I think in any case the Steema module should not throw an out of exception. Yes you are right with the number representation. Interestingly, it seems to only be if ALL the numbers in the series are very close. If one point is added that is not a near identical value, then it doesn't crash.
Thanks for your feedback
