Couldn't Find ItemIndex, errors
Valgardur
Post by Valgardur » Mon Jan 23, 2023 11:21 am
Trying a fairly simple chart using TDBChart, I constantly get "Couldn't find ItemIndex" error message. This does seem to relate to BindingsList, LinkGridToDataSource... I tried to create the connection both manually and with TDBChart's BindVisually.
Is there a demo available with TDBChart that retrieves data (perhaps date / value) from a database (Oracle / MSSQL Server)?
Working with complex DB linked chart's in VCL works fine.
The data displays correctly in a grid when not linked to TDBChart.
I can only find Demos using TChart, not TDBChart.
Using TChart adding the data from the dataset in a loop also works fine.
PS. Working with TDBChart is does create a lot of errors, crash, and strange error messages.
If I create a series, delete and try to create again I get an error message that it already exists.
I repeatedly restarted and cleaned my project, but it seems a lot of junk is left.
Deleting a TDBChart frequently causes Access Violation in Delphi.
Re: Couldn't Find ItemIndex, errors
Post by Yeray » Thu Jan 26, 2023 7:21 am
Are you in RAD 11.2 Alexandria? Just to make sure I do the tests with the same environment.
Valgardur
Post by Valgardur » Thu Jan 26, 2023 12:36 pm
Thanks, yes.
Post by Yeray » Thu Feb 02, 2023 2:15 pm
Sorry for the delay here.
The example here seems to work fine for me here. Could you please give it a try?
Valgardur
Post by Valgardur » Tue Feb 07, 2023 2:28 pm
Thank you for your reply.
I already checked those examples and they do work, but I have a different data.
In the examples some coding is necessary
I would have expected to be possible to do all the linking / binding in design interface. I have dozens of grids that we need to port, it does not look promising if I have to programmatically link the data.
PS. This error message is not very helpful and suggests that this is perhaps not ready.
