What is the relevant to the AxisRect().Top in html ?
aaron
Post by aaron » Tue Apr 25, 2023 1:50 pm
int y1 = TChart.Axes.Left.AxisRect().Top;
int y2 = TChart.Axes.Bottom.AxisRect().Top;
Re: What is the relevant to the AxisRect().Top in html ?
Post by Marc » Tue Apr 25, 2023 3:15 pm
You can get what you need I think, from:
Chart1.chartRect
See use of ChartRect here as an argument for clipping:
https://www.steema.com/files/public/tee ... ighlow.htm
aaron
Post by aaron » Thu Apr 27, 2023 5:25 pm
Hello, this is not the right answer.
If I want to top off the axis value then, what should I do with the chart-level props?
the correct approch is :
 this.TChart.axes.bottom.startPos
aaron
