Colorgrid needs a lot of memory
HQO
Post by HQO » Wed Jan 19, 2005 12:25 pm
Is it really so, that when I do the simply .Net form and add the Tchart with one colorgrid - series and set the Axes.Bottom.Maximum to 1500 Axes.Left.Maximum to 300 and filling this, it needs memory over 110Mb? Sounds quite big, why it so?
And there is no way to free the memory back to original state. I try to use colorGrid.Clean(), colorGrid.Dospose() and tChart.Dispose(), nothing seems to work on that case... any idea how I can free the memory?
I'm using TeeChart version 1.0.1452.42972
BTW, what are the pc requirements when using TeeChart (memory size, ...)?
Post by Narcís » Thu Jan 20, 2005 12:33 pm
Hi HQQ,
This is a problem we are aware of. We are trying to solve it for future releases.
The same as needed to run Visual Studio 2003
HQO
Post by HQO » Fri Jan 21, 2005 1:26 pm
This is REALLY high problem in our project, because we have a application which is open long time and user loads the usercontrol with this TeeChart control (and with colorgrid series) from it. And if colorgrid takes memory around 100MB each time when control is loaded, client will stuck very soon.
So, if you don't have any workaround for this, please try to set the piority to fix this very high. Also please inform when the fix will be available.
Thank's
Post by Pep » Tue Jan 25, 2005 11:20 am
I've just sent to your mail a test project so you can check it and let me know some information about the performance.
