_Headers : invalid property value C++ FMX (win32 only)
Ludo
Post by Ludo » Mon Mar 10, 2025 9:18 am
Hello support,
i encounter the same issue.. only when i build as a win32 fmx application.
reproduce :
- Create a new multiplatform application c++
- build and run successful
- drop a teegrid component (1.17) on the form
- build/run gives the error TeeGrid1 ._Headers:invalid property value.
- switch to 64bit
- switch back to 32bit
- open form as text and remove the _Headers section
- save file
- close file and do not open the designer
- open form
- open designer and move the teeGrid
- save the change
- build/run gives the error TeeGrid1._Headers:invalid property value.
My applications consists of many lists where the teegrid is used. normally i make 64 bit applications only but for a project where i only have access to specific 32bit libraries i ported my bases forms to 32bit.. the workaround may work but is not workable and not maintainable..
Please investigate for a permanent sollution.
Re: _Headers : invalid property value C++ FMX (win32 only)
Post by Marc » Mon Mar 10, 2025 9:30 am
Ludo
Post by Ludo » Mon Mar 10, 2025 10:09 pm
installed rad studio 12.2 with patch 2 RAD Studio 12 Version 29.0.53982.0329
and version 1.17 of teegrid.
unfortunately the same result.. so the issue does not seem to be fixed with the newest version of RadStudio and the latest teegrid
any thoughts how to fix ?
i use FMX not VCL
Post by Marc » Tue Mar 11, 2025 10:52 am
Yes, the error has appeared again for the latest C++ Windows x64 but works fine with modern C++ Windows x64. We'll take another look. Embarcadero recommends the use of modern.
Ludo
Post by Ludo » Thu Mar 13, 2025 2:16 pm
The issue lies with 32bit only..
so even if modern is the way to go.. (i agree) this is not the focus. for now all implementations i have work properly for WIN64 but not WIN32... i only require the 32bit to work (i would be open to try a development version and provide feedback on my findings)
i have no trouble with the x64 bit (our production is still running c++ 12.0 with teegrid 1.17) but i am testing the working on a seperate system with 12.2 and teegrid 1.17.. for 32bit this failed.. 64bit worked.
Post by Marc » Tue Mar 18, 2025 9:00 am
This issue has been a moving target, resulting with correct functioning for certain RAD Studio 12 patch releases. As you point out, it only affects C++ projects. We are checking this now with RAD Studio update 3.
For your purposes, it may be acceptable to you (?) to disable the _Headers property from being saved to the Form at designtime. If you do that (as described below) old projects will report a TeeGrid error on first opening, but ignoring it will continue and any small change to the form, re-saving it, will resave the TeeGrid to the form without the 'offending' property.
The workaround is to comment Filer.DefineProperty('_Headers' in the TeeGrid.pas file and to rerun the TeeGridRecompile installer, to rebuild and re-install the modified source to RAD Studio:
ie.
procedure TCustomTeeGrid.DefineProperties(Filer: TFiler);
  function CanPersistData:Boolean;
    result:=(FData<>nil) and TDataAccess(FData).Streamable;
  inherited;
  Filer.DefineProperty('_Data',ReadData,WriteData,CanPersistData);
  Filer.DefineProperty('_Footer',ReadFooter,WriteFooter,Footer.Count>0);
  //Filer.DefineProperty('_Headers',ReadHeaders,WriteHeaders,Headers.Count>0);
TeeGrid will no longer save a designtime set Header for runtime, but that is easily solved by adding the header by code.
I hope that may allow you to move forward. We will report back on findings with RAD Studio 12.3.
