Display "virtual" series?
dummzeuch
Post by dummzeuch » Mon Jun 16, 2025 12:21 pm
I would like to display a chart with data that is too large to be stored in memory, so using regular TLineSeries or TFastLineSeries won't work. The data is also not stored in a database but in a proprietary binary file format, so using a TDbChart also won't work for this.
Is there any kind of line series that e.g. has a callback for getting the Y value for a given X value or something similar?
Or any other way to achieve this?
Of course I could create a line series that only contains data for a given span of X values and update the data in the series every time the user pans the chart horizontally, but I hope there is a simple way of doing this.
Re: Display "virtual" series?
Post by Yeray » Mon Jun 16, 2025 4:44 pm
Indeed, the easier approach would be to dynamically load the data you need. Ie:
  Chart1: TChart;
  Series1: TPointSeries;
const FileName= 'D:\Downloads\data.csv';
const step=50;
  Chart1:=TChart.Create(Self);
  with Chart1 do
    Parent:=Self;
    Align:=alClient;
    Color:=clWhite;
    Gradient.Visible:=False;
    Walls.Back.Color:=clWhite;
    Legend.Hide;
    View3D:=False;
    Series1:=TPointSeries(AddSeries(TPointSeries));
    with Series1 do
      Pointer.Size:=2;
      LoadData(0, step*2-1);
procedure TForm1.LoadData(AStartLine, AEndLine: Integer);
  Reader: TStreamReader;
  CurrentLine: Integer;
  tmpLine: string;
  tmpFields: TArray<string>;
  Series1.Clear;
  Reader:=TStreamReader.Create(FileName);
  try
    CurrentLine:=0;
    while (not Reader.EndOfStream) and (CurrentLine <= AEndLine) do
      if (CurrentLine >= AStartLine) and (CurrentLine <= AEndLine) then
        tmpLine:=Reader.ReadLine;
        tmpFields:=tmpLine.Split([';']);
        if Length(tmpFields)<2 then
          Continue;
        Series1.AddXY(StrToInt(tmpFields[0]), StrToFloat(tmpFields[1]));
      end
        Reader.ReadLine;
      Inc(CurrentLine);
  finally
    Reader.Free;
  BPrev.Enabled:=Series1.XValues.First>0;
  BNext.Enabled:=Series1.XValues.Last<999;
procedure TForm1.BPrevClick(Sender: TObject);
  if Series1.Count=0 then
    Exit;
  LoadData(Round(Series1.XValues.First)-step,
           Round(Series1.XValues.Last)-step);
procedure TForm1.BNextClick(Sender: TObject);
    Exit;
  LoadData(Round(Series1.XValues.First)+step,
           Round(Series1.XValues.Last)+step);
