I tried to download and install TeeGrid-Registered-1.18.exe.
But I get an error that "vkSpace" cannot be found.
Please tell me how to fix it.
I'm using Lazarus 4.0
Thank you for your kindness.
Error message : Identifier not found "vkSpace"
Re: Error message : Identifier not found "vkSpace"
I've just sent you mail with the link to download the same zip I prepared for another customer, which contains a fix for that error, and the password to extract it.
I received the file you sent and completed the package installation. Thank you for your help.
However, the program crashes while editing the Columns title using the Editor. I tested it using Lazarus 4.0, I'll test it a bit more and ask again if it's still a problem.
I've been playing with the Colums Title without observing any crash. Could you please detail what should I do to reproduce the problem?
Most of the time it works fine. But sometimes when I input Header text (in Korean) and click somewhere else like ListBox (when Memo Box where Header text is input loses focus), Lazarus freezes.
This happens sometimes. So it's hard to explain the specific situation where it happens.
- Error Full.png (457.8 KiB) Viewed 36463 times
I've been adding and removing columns without any freezing so far.
If you find a solid way to reproduce the problem, please don't hesitate to let us know.
