Chris
- Newbie
Post
by Chris » Mon Jan 24, 2005 3:23 am
How do you set a single existing point? In VB/ActiveX:
tcMyChart( 2 ) .Series(0).PointValue(i) = 35
This is a simple 1 series, flat barchart.
Marjan
Post
by Marjan » Mon Jan 24, 2005 10:04 am
Hi.
How about this:
Chart1.Series[0].YValues.Value[i] := 35;
Chris
- Newbie
Post
by Chris » Mon Jan 24, 2005 1:32 pm
Marjan wrote:Hi.
How about this:
So PointValue is an ActiveX translation for the YValue(s) ?
That worked, thanks much.
Post
by Pep » Tue Jan 25, 2005 9:16 am
Hi Chris,
Not exactly, PointValue property was designed to return the value of the Series point at the index specified, but it allows you to set a Value too.
In the ActiveX version you can also use the YValue(s) property to set a value.
Chris
- Newbie
Post
by Chris » Wed Jan 26, 2005 8:36 pm
What about
ActiveX: objChart.Axis.bottom.Position
Edit: It appears to be
