Color disappear when I change a level value
Grunvald
Post by Grunvald » Fri Mar 11, 2005 4:52 pm
I have a TContourSeries which contains lots of XYZ value.
When I write the following lines :
Series.CreateAutoLevels;
Series.NumLevels := 10;
Series1.EndColor := clBlue;
Series1.MidColor := ClGreen;
Series1.StartColor := clRed;
Series1.UseColorRange := true;
With that, the color palette is good.
I would like to have the possibility to draw the levels with a specified value.
For example, I write :
Series.Levels [0].UpToValue := 50;
But when I add this line, all the color become white and I lose all the color palette...
Can you help to find the solution ??? :cry:
Post by Pep » Mon Mar 21, 2005 4:25 pm
you should define each level value, as in the following code :
  Series1.NumLevels:=10;
  Series1.CreateAutoLevels;
  With Series1.Levels do
    Items[0].UpToValue:=-1;
    Items[1].UpToValue:=-0.8;
    Items[2].UpToValue:=-0.6;
    Items[3].UpToValue:=-0.4;
    Items[4].UpToValue:=-0.2;
    Items[5].UpToValue:= 0;
    Items[6].UpToValue:= 0.2;
    Items[7].UpToValue:= 0.4;
    Items[8].UpToValue:= 0.6;
    Items[9].UpToValue:= 0.8;
