MTB
- Newbie
Post
by MTB » Tue Nov 18, 2003 6:27 pm
I have created a demo project showing this problem. It looks like a bug to me. (Of course it could be something I'm doing incorrectly too.)
I really need some quick help with this problem and I sent an email to tech support with my demo project attached. However, I received the following response: "Please be aware that this email address is no longer in use."
Is there any way I can get some quick help on this issue? (I have a pro support contract.) I have a fast approaching deadline for demonstrating TeeChart and I've been going round and round on this issue for close to a week now.
I have just created a new demo project that shows the problem even more clearly. The code is a bit long, so I don't think it makes sense to post it here.
Post
by Pep » Tue Nov 18, 2003 11:20 pm
Hi David,
we've received your email with the demo project. We'll review it and let you know something asap.
Josep Lluis Jorge
http://support.steema.com
MTB
- Newbie
Post
by MTB » Tue Nov 18, 2003 11:31 pm
Thank you, thank you! I'm really pushing hard on this deadline and I still have not found solutions for several problems. This one regarding MaximumOffset and MinimumOffset is one of the toughest for me. I appreciate your help.
MTB
- Newbie
Post
by MTB » Thu Nov 20, 2003 2:47 pm
Thanks for sending me a work around. I'm posting here so everyone can benefit from the solution.
David
//The next couple of lines are the workaround to the CustomVertAxis.MaximumOffset
//defect.
double offset = lineSeries.YValues.Maximum * 0.1;
lineSeriesAxes.SetMinMax(lineSeries.YValues.Minimum - offset, lineSeries.YValues.Maximum + offset);
//the lines below do not have the intended effect:
//no extra margin at the ends of the axis is set.
// lineSeries.CustomVertAxis.MaximumOffset = 5;
// lineSeries.CustomVertAxis.MinimumOffset = 5;
MTB
- Newbie
Post
by MTB » Sun Nov 23, 2003 11:21 pm
I found an issue when using this workaround. My line series often begin as a line with no slope thru the origin (i.e., y = 0 for all x).
Every line series like this (after the first one) causes the right custom axis to show zeros at each tick mark and the line series doesn't display.
The workaround I had to do is as follows:
public static void MinimumMaximumOffset(Series series, Axis axis)
if (series.YValues.Maximum == 0 && series.YValues.Minimum == 0)
return;
double offset = series.YValues.Maximum * 0.05;
axis.SetMinMax(
series.YValues.Minimum - offset,
series.YValues.Maximum + offset);
}//MinimumMaximumOffset
nico193
- Newbie
Post
by nico193 » Fri Jan 16, 2004 9:32 am
The minimum offset and maximum offset are still not working on latest release. Is this normal ? Do you consider this a s a bug ?
Post
by Marc » Fri Jan 16, 2004 12:58 pm
Thanks for letting us know. This can be considered a bug and is now fixed for the next maintenance release (availability end of January).
nico193
- Newbie
Post
by nico193 » Fri Jan 16, 2004 2:10 pm
Thanks !! I'll download it !
MTB
- Newbie
Post
by MTB » Fri Jan 16, 2004 3:38 pm
Just curious, is there any difference in features or fixes between the VS2002-only version (16-Jan-2004 date) and the "latest binary" version compatible with VS2003 (24-Dec-2003 date)? If I have VS2002 and want the latest, greatest TeeChart code, which version should I download? Thanks!
Post
by Marc » Fri Jan 16, 2004 5:54 pm
Both versions are identical in featureset, there is no feature disadvantage to using either version.
The VS2002 compiled version contains TeeChart dlls, all examples and the installer utilities built with the VS2002 framework.
