Alternative TGauge labels
bdw
Post by bdw » Thu May 19, 2005 9:13 am
We have TChart 7.04 VCL. I was trying to display alternative axis labels on the TGauge graph but have had no luck. With the TLineSeries this could be done with code similar to :-
TChartAxis *axis = graph_->Axes->Right;
axis->Items->Clear(); // remove all custom labels
// add custom labels
axis->Items->Add(0.0, "N");
This does not seem to work with the TGauge even if you get the TGaugeSeries.Axis.......
TIA,
Brett
Post by Pep » Thu May 26, 2005 10:23 am
Hi Brett,
for the moment the only way to do this (using Gauge Series) is by setting the Left axis labels visible to False (which are the labels of the Gauge) and then use the Canvas techniques to draw text on the Canvas.
This feature is on our wish list to be considered for further releases.
bdw
Post by bdw » Thu May 26, 2005 8:35 pm
Thanks Pep for the reply.
It took me a while to work out but your suggestion was the work around I was using.
I have it working to some extent at the present time, however I seem to strike a probelm when I try and use the AngleToPos() function and the RotationAnlge is not set to 90 or 270, can someone explain this function ?
The angle passed to AngleToPos() is a radian value but I need to make it negative to display correctly at 90 and 270.........at any other rotation angle the values are all over the place......
Thanks for any help,
Brett
Post by Narcís » Fri May 27, 2005 7:29 am
Hi Brett,
According to TeeChart help files:
procedure AngleToPos(Const Angle, AXRadius, AYRadius: Double; Var X, Y: Integer);
Description
The AngleToPos functions returns the exact Screen position for a given pair of Angle and Radius values.
Angles must be expressed in radians from 0 to 2*PI. Radius parameter is in number of pixels.
bdw
Post by bdw » Wed Jun 01, 2005 2:42 am
I guess I didn't explain myself enough, I was aware of the help file definition of the AngleToPos() function. My question is why do I need to put in a negative angle to get the correct screen coordinate when the RotationAngle propertie is set to 90 or 270 degrees ?
When its not a 90 or 270 degrees I don't get the screen coordinate that corresponds to the angle put into the AngleToPos() function ?
Thanks for you help,
Brett.
Post by Pep » Thu Jun 16, 2005 8:32 am
Hi Brett,
using similar code to the following code (which is the one used to show the labels) you should be to draw your custom labels :
Procedure Tform1.DrawAngleLabel(Angle:Double; AIndex:Integer);
 { MS : 5.02 - replaced old code }
    var X         : Integer;
        Y         : Integer;
        tmpHeight : Integer;
        tmpWidth  : Integer;
        AngleRad  : Double;
        tmpSt     : String;
        tmpXRad   : Integer;
        tmpYRad   : Integer;
        tmpMult   : Integer;
        tmpMargin : Double;
      With Chart1.Canvas do
//        AssignFont(CircleLabelsFont);
        tmpHeight:=FontHeight;
        if Angle>=360 then Angle:=Angle-360;
        tmpSt:=  GetCircleLabel(Angle,AIndex);
        tmpXRad:=XRadius;
        tmpYRad:=YRadius;
//          tmpMargin:=LabelsMargin/100.0;
        Inc(tmpXRad,Round(tmpXRad*tmpMargin));
        Inc(tmpYRad,Round(tmpYRad*tmpMargin));
        AngleToPos(Angle*PiDegree,tmpXRad,tmpYRad,X,Y);
        Angle:=Angle+RotationAngle;
        AngleRad:=Angle*PiDegree;
        if CircleLabelsRotated then
          if (Angle>90) and (Angle<270) then
             tmpMult:= 1  { right aligned }
             tmpMult:=-1; { left aligned }
          Inc(X, tmpMult*Round(0.5*tmpHeight*Sin(AngleRad)));
          Inc(Y, tmpMult*Round(0.5*tmpHeight*Cos(AngleRad)));
        if FCircleLabelsRot then
            TextAlign:=TA_RIGHT;
            Angle:=Angle+180;
          end
          else TextAlign:=TA_LEFT;
          RotateLabel3D(X,Y,EndZ,tmpSt,Angle);
        end
          if (Angle=0) or (Angle=180) then Dec(Y,tmpHeight div 2)
          if (Angle>0) and (Angle<180) then Dec(Y,tmpHeight);
          if (Angle=90) or (Angle=270) then TextAlign:=ta_Center
            if FCircleLabelsInside then
               if (Angle>90) and (Angle<270) then TextAlign:=ta_Left
                                             else TextAlign:=ta_Right
               if (Angle>90) and (Angle<270) then TextAlign:=ta_Right
                                             else TextAlign:=ta_Left;
          tmpWidth:=TextWidth('0') div 2;
          if Angle=0 then Inc(x,tmpWidth) else
          if Angle=180 then Dec(x,tmpWidth);
          TextOut3D(X,Y,EndZ,tmpSt);
while tmpValue<360 do
      DrawAngleLabel(tmpValue,tmpIndex);
      tmpValue:=tmpValue+tmpIncrement;
      Inc(tmpIndex);
