Spacing of characters in WMF
Ed
Post by Ed » Tue May 31, 2005 7:38 pm
I am getting a few complains from users in printing out a chart that contain the word 'Growth'--it appears that that there is a space between the 'w' and the 't', i.e. 'Grow th'. I have reproduced this in a demo that shows a similar problem at run time with a WMF image (but it does not occur with a bitmap (there is a check box in the demo to show this) or if I directly print the chart to the printer, i.e. Chart1.Print).
The demo can be downloaded from:
www.retireneeds.com/files/TeeChartGrowthSpacing.zip
Note that the problem is more apparent in a print out.
Any suggestions on solving this?
Ed Dressel
Post by Narcís » Fri Jun 03, 2005 8:48 am
Hi Ed,
Thank you very much for your demo but it seems to work fine here using latest TeeChart version (v7.04). Which TeeChart version are you using?
Ed
Post by Ed » Fri Jun 03, 2005 4:51 pm
Thank you very much for your demo but it seems to work fine here using latest TeeChart version (v7.04). Which TeeChart version are you using?[/quote]
7.04. The problem is much more subtle when showing in the graphics adapter vs. the printer. But the ‘w’ and ‘t’ do not touch vs. all of the other characters do. A few of my users see ‘grow’ and ‘th’ as separate words.
Post by Pep » Sun Jun 05, 2005 9:37 am
Hi Ed,
maybe the problem is the video card driver. Have you tried another compatible video card driver (check if there's a new version in the manufacturer web).
