Contours and removing dots in a Smith Chart ?
Carsten
Post by Carsten » Wed Oct 19, 2005 4:33 pm
Can I plot contours in a Smith Chart ?
Can I overlay my Smith Chart with a Contours plot where the Contour plot is 100% inside the SmithChart Circle ?
Also,- how do I remove,- or change, the data dots ?
Best regards
Carsten
Post by Pep » Mon Oct 24, 2005 11:04 am
Hi Carsten,
No, these features aren't available in the latest TeeChart Pro version
I'm not sure what you refer here, if you mean about how to manipulate the Smith points, you could see all the methods and properties of this Series type in the Help File, searching for TSmithSeries. For example to remove a datapoint you can use Series1.Delete(i);
