Axis.LabelsOnAxis does nothing
fnn
Post by fnn » Tue Feb 28, 2006 8:42 am
Axis.LabelsOnAxis is only used in InternalDrawLabel
LabelsOnAxis may be useful to not show labels out of Axis.MinimumOfset and Axis.MaximumOfset.
Also all labels should be in Axis.IStartPos and Axis.EndPos
Also Minimum Label rectangle should start Axis.EndPos to prove that multiple axis labels do not overlap.
Post by Pep » Thu Mar 02, 2006 10:50 am
The LabelsOnAxis property does not check this, as designed, but this can be solved by using the OnGetAxisLabel event :
if StrToFloat(labeltext) < Chart1.Axes.Bottom.Minimum then
labeltext := '';
I'm not sure what you refer here ..
>Also Minimum Label rectangle should start Axis.EndPos to prove that >multiple axis labels do not overlap.
You could solve this by setting an offset
fnn
LabelsOnAxis
Post by fnn » Wed Mar 08, 2006 7:45 am
Firstly, StrToFloat(labeltext) is string.
It should be a double value to compare with Chart1.Axes.Bottom.Minimum.
Secondly,
For Chart1.Axes.Bottom.Minimum,
setting labeltext= '' has a potential problem.
Axis.MaxLabelWidth property uses mininum value.
So, Axis.MaxLabelWidth may be zero or less than actual value
I have multiple vertical axes, their start and and position are same.
So sometimes, their minimum and maximum labels overlaps.
This proves that all labels are not in Axis.IStartPos and Axis.EndPos.
fnn
LabelsOnAxis
Post by fnn » Wed Mar 08, 2006 7:56 am
I solve my problem by changing source code as below
set FLabelsOnAxis=false
Procedure InternalDrawLabel(var Value:Double; DecValue:Boolean);
var tmp,s,e,h : Integer;
Begin
h:=LabelHeight(Value)div 2;
if StartPosition=0 then
s:=0
s:=h;
if EndPosition=100 then
e:=0
e:=h;
if FLabelsOnAxis or ((tmp-s>IStartPos) and (tmp+e<IEndPos)) then
