TeeChart for .NET UPDATE BUILD v1.1.2259.29262
Post by Christopher » Tue Mar 14, 2006 2:32 pm
The latest update build is now available from Steema's Customer Download pages.
The release notes for this update build can be read here:
http://www.steema.com/files/public/TeeC ... elease.txt
Thank you!
http://groups.google.com
http://codenewsfast.com/
tchart_user
Update v1.1.2259.2926 works on develement computer, but ext.
Post by tchart_user » Tue Mar 28, 2006 3:23 pm
I have installed v1.1.2259.29262 and it works fine on my develement coumputer, boch in the studio envement, and outsite.
I have run the "TeeReg.exe" more that ones.
Then i try my application on a nother computer i get this error :
System.NullReferenceException: Object reference not set to a instance of an object.
at Steema.TeeChart.FrAccessProvider.GetLicense(LicenseContext context, Type type, Object instance, Boolean allowExceptions. License& license, String& licenseKey)
at System.ComponentModel.LicenseManager.ValidateInternal(Type type, Object instance, Boolean allowExceptions, License& license)
at System.ComponentModel.LicenseManager.Validate(Type type, Object instance)
at Steema.TeeChart.Chart..ctor()
at Steema.TeeChart.TChart..ctor()
best regards Poul-Erik Hansen.
Post by Narcís » Wed Mar 29, 2006 8:15 am
Hi Poul-Erik,
Have you followed the instructions at Tutorial 17 - Designtime, Runtime and License Requirements?
tchart_user
Post by tchart_user » Thu Mar 30, 2006 10:26 am
I have read Tutorial17, and I don't use "TeeChart.Languages".
If i replaces the TChart.dll with the version 1.1.1499 all seams to work.
mvh. Poul-Erik Hansen.
Post by Marc » Thu Mar 30, 2006 12:06 pm
Hello Poul-Erik,
We'll need to know a little bit about the project setup. Is the solution a Windows desktop exe, a dll or a Webproject or other?
Version 1.1.1499 is pre-license version, so some modifications will need to be made to your project to make it license compatible. Have you included a Licences.licx file in the project?
With thanks.
tchart_user
Post by tchart_user » Thu Mar 30, 2006 12:48 pm
My application isn't a web project.
I am using Visual C#.net version 7.1.3088
.NET framework 1.1 Version 1.1.4322 SP1
My application run fine on my computer, by then i install the application on a nother computer i get this error.
I have tested it on Windows XP and Windows 2000.
I can see that a file called "licenses.licx" is include automatckly then i add teecharte object to my user form, and the i repleace the new files by the old from version 1.1.1499 my application runs on every computer.
best regards Poul-Erik.
Post by Marc » Wed Apr 26, 2006 10:08 am
Hello Poul-Erik,
It seems we missed follow up to this issue. Is the problem resolved?
cp
Can you give me the possiblely date of new release?
Post by cp » Wed May 03, 2006 6:56 am
Because of this bug is urgent to me, Can you give me the possiblely date of new release?
Post by Marc » Wed May 03, 2006 9:26 am
We don't believe there is a bug here. Please describe to us the symptoms of the problem and we'll try to help resolve it.
