[Bug] - multiple Cursortool
moelski
Post by moelski » Thu Jul 05, 2007 5:52 am
Hi !
I think I found a bug in the cursortool ...
The way to reproduce it:
1) add 2 CursorTools to the Tools section
2) Both have the same series and the style is Scope
3) Both are activated
4) Compile / Start the application and you won´t see any corsor tool within the chart
5) Add some data to the chart
6) execute the ChartEditor (I use TeeComander for this) and try to activate one of the CursorTools
Now you will see that only cursortool 2 is activated. No matter if you use the active checkbox from cursortool 1 or 2.
Close the ChartEditor and move the visible cursortool. Enter the charteditor again and you can enable charttool 1 as usual.
Really strange thing :D
Hopefully you can fix this in the next time. Because we need the Cursortools for measurement in our application.
If it is necessary I can send you a demo.
Now
Post by Yeray » Thu Jul 05, 2007 7:45 am
Hi Dominik,
Yes, this is a known bug already listed on our defect list to be fixed for future releases (TV52011928).
The problem is that when you have 2 cursors in the same position they are not visible anymore.
moelski
Post by moelski » Thu Jul 05, 2007 7:47 am
Ups, sorry for doublereporting ...
Well ... The workaround could be to set the position of cursortool2 by code? And after that I activate it ?
Would this work ?
Post by Narcís » Thu Jul 05, 2007 8:26 am
Hi Dominik,
No problem, better twice than none :wink:.
Setting different tools position should be enough.
moelski
Post by moelski » Thu Jul 05, 2007 8:33 am
Hi !
Ok, but where / how can I set the position.
I can´t find a prope methode for this.
Post by Narcís » Thu Jul 05, 2007 2:47 pm
Hi Dominik,
Here's an example of changing cursor's position at run-time.
