tutorial
MTW
tutorial
Post by MTW » Mon Jul 09, 2007 6:00 pm
I am using TChart V8.0 (BCB 6.0). Where are the tutorials now located for download? They do not appear to be included with the downloaded software.
M Weingarden
Post by Yeray » Tue Jul 10, 2007 9:12 am
Hi Weingarden,
If you are not a source code customer you can find the demos and tutorials are at the same place as older versions, at TeeChart entry at Start Menu>All Programs.
Otherwise, if you are a source code customer to obtain the docs, tutorials and examples you need to install the binary installer (without sources) and then install the binary installer (with sources).
MTW
Post by MTW » Tue Jul 10, 2007 6:41 pm
I do not have the source code. Apparently, the file TeeChart8Manual.chm was not included with TeeChart8 install files for BCB6. Can it be downloaded from somewhere?
Post by Yeray » Tue Jul 24, 2007 9:17 am
Hi Weingarden,
Could you please tell us what version of TeeChart are you using exactly?
If you have TeeChart Pro, you should have the help and doc files at the Docs folder in your TeeChart installation folder.
