Sort problem returned
Jack007
Post by Jack007 » Thu Apr 29, 2004 8:45 am
After migrating from AXV5 to AXV6 there was the problem that in a stored (V5) *.tee file which was read by AXV6 that not-sorted series were sorted.
After installing the maintanance release V6.0.05 it looked like the problem diaspeared. And indeed reading a V5 *.tee was read correctly. But reading a V6 (6.005) stored *.tee with non-sorted series are getting sorted again.
Jack
Post by Christopher » Fri Apr 30, 2004 9:16 am
Hi Jack,
I've been able to reproduce this problem here and have added it to the list of defects for TeeChart AXv6, meaning that a fix to it will be considered for inclusion into the upcoming maintenance release.
Thank you!
http://groups.google.com
http://codenewsfast.com/
Jack007
Post by Jack007 » Fri Apr 30, 2004 12:03 pm
Hi Chris,
Well a simular problem did arise when i wanted to upgrade fron V5 to V6 and i had to wait for 6.0.05. Now 6.0.05 arrived and i still can't use it. So when is the maintanance release due ?
Greetings,
Jack
Post by Pep » Tue May 04, 2004 8:35 am
Hi Jack,
there's not a date fixed. The TeeChart Pro v7 will be available shortly, in a few weeks.
Jack007
Post by Jack007 » Tue May 04, 2004 10:41 am
Hi Pep,
I purchased V6 as an upgrade on my V5 but I could never use V6 because of the sort problems.
I guess you understand that i'm somewhat reluctant to purchase V7 (wil it work?; should i pay again for something i should have bought with V6).
I presume that a fix for V6 would be the best solution.
Greetings
Jack
Post by Pep » Wed May 05, 2004 2:02 pm
Hi Jack,
ok, I think we'll prepare a new maintenance relaase of v6. We'll try to include a fix for that.
Post by Christopher » Wed May 05, 2004 2:49 pm
Hi Jack,
I can confirm that the fix will be included in the next AXv6 maintenance release.
Thank you!
Jack007
Post by Jack007 » Thu May 06, 2004 7:02 pm
Thanx,
That was the response i was looking for.
Jack
