ASP.NET WebChart Zoom Bugs
EC
Post by EC » Thu Apr 03, 2008 1:58 pm
I have found the following issues when using the WebChart control in ASP.NET webform when using the Zoom tool:
1. When using WebChart in a user control, and having two instances of the user control on a web form, zooming only works for the first chart. Note that in this instance that the zecond chart also zooms
2. Having two instances of the WebChart control on a web form, with only the second chart having a ZoomTool configured, causes zooming not to work. Note that when a ZoomTool is configured for the first, zooming does work
For the first scenario I suspect the cause for this is the use of WebChart.ID instead of WebChart.ClientID / WebChart.UniqueID when generating the javascript that is embedded in the page. In the second scenario it seems that not all javascript is emitted.
Please indicate if this is indeed a bug, or if there is a misconfiguration? I have uploaded a sample web application at http://www.steema.net/upload/
EC
Post by EC » Wed Apr 09, 2008 7:25 am
Any feedback on this?
Post by Marc » Fri Apr 11, 2008 4:02 pm
Thanks for the bugreport and thought on it.
Your deduction is correct, that the issue relates to the use of ID instead of ClientID. The problem has been corrected and the fix will be included in the next maintenance release.
