Unhappy out of box experience.
JeffS
Post by JeffS » Tue May 20, 2008 7:24 pm
TeeChart 8.0x/VCL nonfunctional:
1) Rad Studio 2007, fresh install.
2) TeeChart 8.02 install proceeds normally.
3) Build the simplest application imaginable: default VCL Forms project, add TChart + barchart, build (goes normally) but at run time "EClass not found/Class TBarSeries not found". Same result for pie chart.
Obviously, some DLLs are missing from the PATH. Where might the install have gone wrong? Saw no symtoms of anything amiss at any time.
Post by Yeray » Wed May 21, 2008 7:54 am
Hi JeffS,
This seems really similar to this or this, for example.
Please check that the search path and the packages installed are the correct ones.
JeffS
Post by JeffS » Wed May 21, 2008 2:11 pm
I'm afraid my problem is not similar to the ones you pointed me at: these describe "Component Already Exists" errors; mine is one of "Component Not Found".
Help me with what the correct configuration should be:
  • * In the global search path
    * In the IDE configued design time package list
    * In the IDE configured run time package list
TIA, Jeff
Post by Narcís » Wed May 21, 2008 2:20 pm
Hi Jeff,
You may need to register all series styles at runtime using TeeEditPro as described here.
Hope this helps!
JeffS
Post by JeffS » Wed May 21, 2008 5:40 pm
Thanks Narcis,
#pragma link "TeeEditPro"
(using CBuilder) did the trick. I'm a little surprised the necessary registrations do not happen automatically -- I ran into no such issues with release 6.
Jeff
