Solved-Cannot install TQRChart with QuickReport 4 Pro and D5
eegirl
Post by eegirl » Mon Aug 11, 2008 3:50 pm
I am having great difficulty installing TQRChart with QuickReport 4 Pro and Delphi 5. I continually get one of the two following message:
"Cannot load package 'Tee50.' It contains unit 'TeeAbout,'; which is also contained in package 'Tee75'.
I click OK, then the TeeChart 7 for QuickReport is unchecked in the Design packages window. When I attempt to check it (for inclusion), I get the following message:
"Cannot load package 'qrpt50.' It contains unit 'QRWizard,'; which is also contained in package 'QR4RunD5'.
When examining the D5 Project Options, no Design package is named qrpt50, nor does any package have qrpt50 listed as a 'Requires' EXCEPT DclTQR75.dpk that requires TeeQR75.dcp - which requires QRpt50.dcp ???
This looks like a circular reference.
The Runtime packages edit window includes qrpt50.
I have installed TeeChartStandard7.06Delphi5 multiple times to no avail.
I have tried removing qrpt50 completely from the computer, to no avail.
This feels utterly hopeless.
Any help would be greatly appreciated.
Post by Yeray » Tue Aug 12, 2008 8:30 am
Hi eegirl,
Have you solved this issue? The same article I mentioned here will probably help you here if you still have problems.
