Legend items vertically ordered ?
bsonnino
Post by bsonnino » Fri May 21, 2004 5:19 pm
Is there a way to align the legend items vertically ? I have a legend at the bottom of the chart, with three columns. I'd like to get the legend items in vertical order, instead of horizontally.
As an example, I'd like something like
1 4 7
2 5 8
3 6 9
I'm using Teechart 6
Bruno
Post by Pep » Sun May 23, 2004 5:25 pm
Hi Bruno,
there's no way to do this autmatically, but this can be done using the canvas techniques. You can see on example of use in the TeeChart Pro Demo features project under :
All Features -> Welcome -> Miscellaneous -> Legend -> Dawing more text
bsonnino
Post by bsonnino » Mon May 24, 2004 12:12 pm
I've thoght of this, but I have another problem. Later I need the legend the mouse is over in OnMouseMove:
(Sender AS TChart).CalcClickedPart(Point(X, Y), Part);
IF Part.PointIndex >= (Sender AS TChart).Series[0].Count THEN
Exit;
IF Part.Part = cpLegend THEN
FCurrSlice := Part.PointIndex
This will make Part.PointIndex point to the wrong slice, no ?
Bruno
Steve
What about using OnGetLegendPos?
Post by Steve » Thu Oct 28, 2004 8:00 am
You can alter the X and Y coordinates for each Legend item within the LegendRect (found from OnGetLegendRect event)
Look up help on the OnGetLegendPos event
HTH :roll:
