Go to Date
alexiat
Go to Date
Post by alexiat » Thu Mar 19, 2009 12:04 pm
I have a line graph with the x-axis as DateTime. I would like to be able to go to today's date in the graph when the window is first displayed. Is there an easy way to do this?
Post by Yeray » Fri Mar 20, 2009 8:56 am
Hi alexiat,
Yes, you should set your bottom axis min and max manually. Here is a simple example:
var day: TDateTime;
i: Integer;
  Chart1.View3D := false;
  Chart1.AddSeries(TLineSeries.Create(nil));
  Chart1[0].XValues.DateTime := true;
  (Chart1[0] as TLineSeries).Pointer.Visible := true;
  day := Today - 100;
  for i:=0 to 500 do
    Chart1[0].AddXY((day + i), i*i);
  Chart1.Axes.Bottom.SetMinMax(Today - 3, Today + 3);
alexiat
Post by alexiat » Fri Mar 20, 2009 4:08 pm
Thank you!
