Show subset of series in bar chart, but all in datatabletool
AIDev
Post by AIDev » Tue Mar 31, 2009 6:13 pm
I am using the data table tool with a standard bar chart with 8 series. The series are visible by selecting checkboxes in the legend. I would like to be able to limit the bar chart to show a max of 2 series in the bar chart, while still showing all 8 series in the data table. Is this possible?
Post by Narcís » Wed Apr 01, 2009 7:02 am
Hi AIDev,
In that case you can using ClickLegend event like this:
      for (int i = 0; i < 8; i++)
        tChart1.Series.Add(new Steema.TeeChart.Styles.Bar());
        tChart1[i].FillSampleValues();
      Steema.TeeChart.Tools.DataTableTool dataTable1 = new Steema.TeeChart.Tools.DataTableTool(tChart1.Chart);
      tChart1.Legend.CheckBoxes = true;
      tChart1.ClickLegend += new MouseEventHandler(tChart1_ClickLegend);
    void tChart1_ClickLegend(object sender, MouseEventArgs e)
      int index = tChart1.Legend.Clicked(e.X, e.Y);
      tChart1[index].Active = true;
      if (tChart1[index].Color == Color.Transparent)
        tChart1[index].Color = Steema.TeeChart.Themes.OperaTheme.OperaPalette[index];
        tChart1[index].Color = Color.Transparent;
AIDev
Post by AIDev » Wed Apr 01, 2009 4:41 pm
This works pretty well. Is there a way to shrink the width of the transparent bars, so the visible bars (with transparent bars in between) are directly adjacent? This would make the chart a little clearer to view. For instance, if series 1 and 4 were checked, it would be nice to have series 1 and 4 bars right next to eachother and centered...
Thanks again.[/img]
AIDev
Post by AIDev » Wed Apr 01, 2009 5:48 pm
One other question: The checkbox remains checked with the method above. I cannot find a way to show it as being unchecked when the series is transparent - is there a way to do this?
Post by Yeray » Thu Apr 02, 2009 8:18 am
Hi AIDev,
I'm afraid that dataTable tool wasn't thought to be as customizable as you need to achieve this. Maybe it would be a good idea to allow direct access to this tool's items to customize them, something like the legend.
I've added it to the wish list to be implemented in future releases (TF02014048).
AIDev
Post by AIDev » Thu Apr 02, 2009 11:40 pm
I think I can get around the bar positioning, but the checkbox still displaying is an issue - I think this would be very confusing to the customer. You mention that the legend is more customizable - is there a way I might be able to customize it so that the check does not show when "deselected" using the method responding to the ClickLegend event?
Thanks again.
Post by Yeray » Fri Apr 03, 2009 11:30 am
Hi AIDev,
The legend checkboxes are shown as checked or unchecked automatically depending on if the according series is active or not. So I'm afraid that this is not customizable. But you always can draw a white square over the checkboxes that you want. Here is the code:
int CheckBoxesLeftOffset, CheckBoxesTopOffset, CheckBoxesSize, CheckBoxesSeparation;
    CheckBoxesLeftOffset = 6;
    CheckBoxesTopOffset = 5;
    CheckBoxesSize = 10;
    CheckBoxesSeparation = 17;
    tChart1.Graphics3D.Pen.Visible = false;
    for (int i = 0; i < tChart1.Series.Count; i++)
        if (tChart1[i].Color == Color.Transparent)
            tChart1.Graphics3D.Rectangle(tChart1.Legend.Left + CheckBoxesLeftOffset, tChart1.Legend.Top + CheckBoxesTopOffset + (CheckBoxesSeparation*i), tChart1.Legend.Left + CheckBoxesLeftOffset + CheckBoxesSize, tChart1.Legend.Top + CheckBoxesTopOffset + CheckBoxesSize + (CheckBoxesSeparation*i));
