Rotate and LegendScrollbar
AIS
Post by AIS » Thu Apr 09, 2009 8:34 am
if i have Rotate and a LegendScrollbar tool within a chart the rotate tool overlaps the scrollbar functions.
Try to use the legend scrollbar:
            tChart1.Aspect.Chart3DPercent = 75;
            tChart1.Tools.Add(new Steema.TeeChart.Tools.Rotate());
            tChart1.Tools.Add(new Steema.TeeChart.Tools.LegendScrollBar());
            for (int i = 0; i < 40; i++)
                Steema.TeeChart.Styles.Bar ser = new Steema.TeeChart.Styles.Bar();
                ser.Title = i.ToString();
                ser.FillSampleValues(10);
                tChart1.Series.Add(ser);
How can i avoid this?
Thanks!
Post by Yeray » Thu Apr 09, 2009 9:14 am
Yes it seems that if you create a Rotate Tool and then a LegendScrollBar tool, the LegendScrollBar is undraggable.
Note that if you create the tools in the inverse other, LegendScrollBar and then Rotate tool, both tools work at the same time when you try to scroll the legend.
I've added this to the wish list to be fixed in further releases (TF02014075).
