TPolar DrawZone
Calou
TPolar DrawZone
Post by Calou » Thu May 28, 2009 10:34 am
I an trying to use a TPolar to drawzone like the picture here
but when i call this method nothing occur on my chart
Could it be possible to have help to begin it?
Post by Yeray » Thu May 28, 2009 11:11 am
Hi Calou,
I'm afraid that this would be difficult to draw with the actual TeeCahrt series set. This is already in the wish list (TV52012610) and we'll try to implement it in further releases as several customers demanded for it.
Calou
Post by Calou » Thu May 28, 2009 12:50 pm
Bad news for us :(
Could you explain a little more where is the problem because i saw that we can fill a zone?
Post by Yeray » Thu May 28, 2009 1:47 pm
Hi Calou,
The principal problem is that with PolarGrid series you cannot define the length of each point so that it is uniform. Then tha only think you could do is simulate the effect filling more squares for high values.
Here is a simple example, only to show that this wouldn't be easy to achieve:
uses TeeSurfa;
var i, j: Integer;
  Chart1.Legend.Visible := false;
  Series1.NumSectors := 18;
  Series1.NumTracks := 9;
  for i:=0 to Series1.NumSectors-1 do
    for j:=0 to Series1.NumTracks-1 do
      Series1.AddCell(i, j, clteecolor);
  Series1.Palette.UsePalette := true;
  Series1.Palette.UseColorRange := false;
  Series1.Palette.PaletteStyle := psPale;
  Series1.TreatNulls := tnDontPaint;
  Series1.Centered := false;
  Chart1.Axes.Left.Grid.Visible := false;
  Chart1.Axes.Bottom.Grid.Visible := false;
  Chart1.Axes.Right.Grid.Visible := false;
  Chart1.Axes.Top.Grid.Visible := false;
    Series1.ValueColor[i*Series1.NumTracks] := clWhite;    // center is formed for values index 0, 9, 18, 27,...
  Series1.ValueColor[1] := clNavy;
  Series1.ValueColor[2] := clNavy;
  Series1.ValueColor[3] := clBlue;
  Series1.ValueColor[4] := clBlue;
  Series1.ValueColor[5] := clSkyBlue;
  Series1.SetNull(6);
  Series1.SetNull(7);
  Series1.SetNull(8);
  Series1.ValueColor[10] := clNavy;
  Series1.ValueColor[11] := clBlue;
  Series1.ValueColor[12] := clBlue;
  Series1.ValueColor[13] := clSkyBlue;
  Series1.ValueColor[14] := clSkyBlue;
  Series1.ValueColor[15] := clLime;
  Series1.SetNull(16);
  Series1.SetNull(17);
