Click Events on Series not firing
nico193
Post by nico193 » Thu Jun 11, 2009 4:54 pm
Hello all,
Our application was working perfectly using Steema Teechart for .NET 1.1. We've downloaded the evaluation version for .NET2.0 (Visual Studio 2005) and we're facing a strange problem :
The click events on teechart series are no more firing (they were with the previous version of Steema Teechart under Visual Studio 2003).
The code :
Steema.TeeChart.Styles.Series mySerie = new Steema.TeeChart.Styles.Points;
// [Define Style Color etc ...]
mySerie.Active = true;
mySerie.Cursor = Cursors.Hand;
GraphChart.Series.Add(mySerie );
// Click event
mySerie.Click  += new System.Windows.Forms.MouseEventHandler(this.MyMethod_Click);
mySerie.Visible = true;
private void MyMethod_Click(object sender, System.Windows.Forms.MouseEventArgs e)
   [Some Code]
The "MyMethod_Click" is never called ... Any Idea ??
Thanks for help !
Re: Click Events on Series not firing
Post by Yeray » Fri Jun 12, 2009 2:34 pm
Hi nico193,
I've tested it with your code simply adding some random points to the series and and the event seems to be fired correctly.
Could you please see if it works for you in a simple new application?
        int n;
            Steema.TeeChart.Styles.Series mySerie = new Steema.TeeChart.Styles.Points();
            mySerie.FillSampleValues(25);
            tChart1.Series.Add(mySerie);
            n = 0;
            // Click event
            n += 1;
            tChart1.Header.Text = "Series clicked " + n.ToString() + " times";
nico193
Post by nico193 » Thu Jun 18, 2009 7:58 am
I've created a simple sample to reproduce the issue :
The Form1.designer.cs code :
namespace SteemaTest
    partial class Form1
        /// <summary>
        /// Required designer variable.
        /// </summary>
        private System.ComponentModel.IContainer components = null;
        /// <summary>
        /// Clean up any resources being used.
        /// </summary>
        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
        protected override void Dispose(bool disposing)
            if (disposing && (components != null))
                components.Dispose();
            base.Dispose(disposing);
        #region Windows Form Designer generated code
        /// <summary>
        /// Required method for Designer support - do not modify
        /// the contents of this method with the code editor.
        /// </summary>
        private void InitializeComponent()
            this.GraphChart = new Steema.TeeChart.TChart();
            this.SuspendLayout();
            // GraphChart
            this.GraphChart.Aspect.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.HighSpeed;
            this.GraphChart.Aspect.TextRenderingHint = System.Drawing.Text.TextRenderingHint.SystemDefault;
            this.GraphChart.Aspect.View3D = false;
            this.GraphChart.Aspect.ZOffset = 0;
            this.GraphChart.Axes.Bottom.AxisPen.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Bottom.Grid.Color = System.Drawing.Color.FromArgb(((int)(((byte)(128)))), ((int)(((byte)(128)))), ((int)(((byte)(128)))));
            this.GraphChart.Axes.Bottom.Grid.Style = System.Drawing.Drawing2D.DashStyle.Dot;
            this.GraphChart.Axes.Bottom.Labels.DateTimeFormat = "M/d/yyyy";
            this.GraphChart.Axes.Bottom.Labels.Font.Name = "Arial";
            this.GraphChart.Axes.Bottom.Labels.MultiLine = true;
            this.GraphChart.Axes.Bottom.Ticks.Length = 2;
            this.GraphChart.Axes.Bottom.TicksInner.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Bottom.TicksInner.Visible = true;
            this.GraphChart.Axes.Bottom.Title.Font.Name = "Arial";
            this.GraphChart.Axes.Depth.Automatic = false;
            this.GraphChart.Axes.Depth.AutomaticMaximum = false;
            this.GraphChart.Axes.Depth.AutomaticMinimum = false;
            this.GraphChart.Axes.Depth.AxisPen.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Depth.Grid.Color = System.Drawing.Color.FromArgb(((int)(((byte)(128)))), ((int)(((byte)(128)))), ((int)(((byte)(128)))));
            this.GraphChart.Axes.Depth.Grid.Style = System.Drawing.Drawing2D.DashStyle.Dot;
            this.GraphChart.Axes.Depth.Labels.Font.Name = "Arial";
            this.GraphChart.Axes.Depth.Labels.ValueFormat = "#,##0.00;(#,##0.00)";
            this.GraphChart.Axes.Depth.Maximum = 0.5;
            this.GraphChart.Axes.Depth.Minimum = 0.5;
            this.GraphChart.Axes.Depth.Ticks.Length = 2;
            this.GraphChart.Axes.Depth.TicksInner.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Depth.TicksInner.Visible = true;
            this.GraphChart.Axes.Depth.Title.Font.Name = "Arial";
            this.GraphChart.Axes.DepthTop.AxisPen.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.DepthTop.Grid.Color = System.Drawing.Color.FromArgb(((int)(((byte)(128)))), ((int)(((byte)(128)))), ((int)(((byte)(128)))));
            this.GraphChart.Axes.DepthTop.Grid.Style = System.Drawing.Drawing2D.DashStyle.Dot;
            this.GraphChart.Axes.DepthTop.Labels.Font.Name = "Arial";
            this.GraphChart.Axes.DepthTop.Ticks.Length = 2;
            this.GraphChart.Axes.DepthTop.TicksInner.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.DepthTop.TicksInner.Visible = true;
            this.GraphChart.Axes.DepthTop.Title.Font.Name = "Arial";
            this.GraphChart.Axes.Left.Automatic = false;
            this.GraphChart.Axes.Left.AutomaticMaximum = false;
            this.GraphChart.Axes.Left.AutomaticMinimum = false;
            this.GraphChart.Axes.Left.AxisPen.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Left.Grid.Color = System.Drawing.Color.FromArgb(((int)(((byte)(128)))), ((int)(((byte)(128)))), ((int)(((byte)(128)))));
            this.GraphChart.Axes.Left.Grid.Style = System.Drawing.Drawing2D.DashStyle.Dot;
            this.GraphChart.Axes.Left.Labels.Font.Name = "Arial";
            this.GraphChart.Axes.Left.Labels.Separation = 5;
            this.GraphChart.Axes.Left.Labels.ValueFormat = "#,##0.00;(#,##0.00)";
            this.GraphChart.Axes.Left.Labels.Visible = false;
            this.GraphChart.Axes.Left.Maximum = 0;
            this.GraphChart.Axes.Left.Minimum = 0;
            this.GraphChart.Axes.Left.RelativePosition = 10;
            this.GraphChart.Axes.Left.Ticks.Length = 2;
            this.GraphChart.Axes.Left.TicksInner.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Left.TicksInner.Visible = true;
            this.GraphChart.Axes.Left.Title.Font.Name = "Arial";
            this.GraphChart.Axes.Left.Visible = false;
            this.GraphChart.Axes.Right.Automatic = false;
            this.GraphChart.Axes.Right.AutomaticMaximum = false;
            this.GraphChart.Axes.Right.AutomaticMinimum = false;
            this.GraphChart.Axes.Right.AxisPen.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Right.Grid.Color = System.Drawing.Color.FromArgb(((int)(((byte)(128)))), ((int)(((byte)(128)))), ((int)(((byte)(128)))));
            this.GraphChart.Axes.Right.Grid.Style = System.Drawing.Drawing2D.DashStyle.Dot;
            this.GraphChart.Axes.Right.Labels.Font.Name = "Arial";
            this.GraphChart.Axes.Right.Maximum = 0;
            this.GraphChart.Axes.Right.Minimum = 0;
            this.GraphChart.Axes.Right.Ticks.Length = 2;
            this.GraphChart.Axes.Right.TicksInner.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Right.TicksInner.Visible = true;
            this.GraphChart.Axes.Right.Title.Font.Name = "Arial";
            this.GraphChart.Axes.Right.Visible = false;
            this.GraphChart.Axes.Top.Automatic = false;
            this.GraphChart.Axes.Top.AutomaticMaximum = false;
            this.GraphChart.Axes.Top.AutomaticMinimum = false;
            this.GraphChart.Axes.Top.AxisPen.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Top.Grid.Color = System.Drawing.Color.FromArgb(((int)(((byte)(128)))), ((int)(((byte)(128)))), ((int)(((byte)(128)))));
            this.GraphChart.Axes.Top.Grid.Style = System.Drawing.Drawing2D.DashStyle.Dot;
            this.GraphChart.Axes.Top.Labels.Font.Name = "Arial";
            this.GraphChart.Axes.Top.Maximum = 0;
            this.GraphChart.Axes.Top.Minimum = 0;
            this.GraphChart.Axes.Top.Ticks.Length = 2;
            this.GraphChart.Axes.Top.TicksInner.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Axes.Top.TicksInner.Visible = true;
            this.GraphChart.Axes.Top.Title.Font.Name = "Arial";
            this.GraphChart.Axes.Top.Visible = false;
            this.GraphChart.Cursor = System.Windows.Forms.Cursors.Default;
            this.GraphChart.Dock = System.Windows.Forms.DockStyle.Fill;
            this.GraphChart.Header.Brush.Gradient.EndColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(0)))));
            this.GraphChart.Header.Brush.Gradient.MiddleColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Header.Brush.Gradient.SigmaFocus = 0F;
            this.GraphChart.Header.Brush.Gradient.SigmaScale = 0F;
            this.GraphChart.Header.Brush.Gradient.StartColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(255)))));
            this.GraphChart.Header.Font.Brush.Color = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(255)))));
            this.GraphChart.Header.Font.Name = "Arial";
            this.GraphChart.Header.Pen.Visible = false;
            this.GraphChart.Header.Visible = false;
            this.GraphChart.Legend.Alignment = Steema.TeeChart.LegendAlignments.Left;
            this.GraphChart.Legend.Brush.Gradient.EndColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(0)))));
            this.GraphChart.Legend.Brush.Gradient.MiddleColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Legend.Brush.Gradient.SigmaFocus = 0F;
            this.GraphChart.Legend.Brush.Gradient.SigmaScale = 0F;
            this.GraphChart.Legend.Brush.Gradient.StartColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(255)))));
            this.GraphChart.Legend.DividingLines.Width = 7;
            this.GraphChart.Legend.Font.Name = "Arial";
            this.GraphChart.Legend.TextStyle = Steema.TeeChart.LegendTextStyles.XAndValue;
            this.GraphChart.Legend.Visible = false;
            this.GraphChart.Location = new System.Drawing.Point(0, 0);
            this.GraphChart.Name = "GraphChart";
            this.GraphChart.Panel.Brush.Color = System.Drawing.Color.FromArgb(((int)(((byte)(240)))), ((int)(((byte)(240)))), ((int)(((byte)(240)))));
            this.GraphChart.Panel.Brush.Gradient.EndColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(0)))));
            this.GraphChart.Panel.Brush.Gradient.MiddleColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Panel.Brush.Gradient.SigmaFocus = 0F;
            this.GraphChart.Panel.Brush.Gradient.SigmaScale = 0F;
            this.GraphChart.Panel.Brush.Gradient.StartColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(255)))));
            this.GraphChart.Panel.Brush.Gradient.UseMiddle = false;
            this.GraphChart.Panel.Brush.Gradient.Visible = false;
            this.GraphChart.Panel.Brush.Visible = false;
            this.GraphChart.Panel.MarginBottom = 6;
            this.GraphChart.Panel.MarginLeft = 10;
            this.GraphChart.Panel.MarginRight = 0;
            this.GraphChart.Printer.Resolution = 81;
            this.GraphChart.Size = new System.Drawing.Size(839, 509);
            this.GraphChart.TabIndex = 43;
            this.GraphChart.Walls.Back.Brush.Gradient.EndColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(0)))));
            this.GraphChart.Walls.Back.Brush.Gradient.MiddleColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Walls.Back.Brush.Gradient.SigmaFocus = 0F;
            this.GraphChart.Walls.Back.Brush.Gradient.SigmaScale = 0F;
            this.GraphChart.Walls.Back.Brush.Gradient.StartColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(255)))));
            this.GraphChart.Walls.Back.Brush.Gradient.Visible = false;
            this.GraphChart.Walls.Back.Brush.Visible = false;
            this.GraphChart.Walls.Back.Transparent = true;
            this.GraphChart.Walls.Bottom.Brush.Gradient.EndColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(0)))));
            this.GraphChart.Walls.Bottom.Brush.Gradient.MiddleColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Walls.Bottom.Brush.Gradient.SigmaFocus = 0F;
            this.GraphChart.Walls.Bottom.Brush.Gradient.SigmaScale = 0F;
            this.GraphChart.Walls.Bottom.Brush.Gradient.StartColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(255)))));
            this.GraphChart.Walls.Left.Brush.Gradient.EndColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(0)))));
            this.GraphChart.Walls.Left.Brush.Gradient.MiddleColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Walls.Left.Brush.Gradient.SigmaFocus = 0F;
            this.GraphChart.Walls.Left.Brush.Gradient.SigmaScale = 0F;
            this.GraphChart.Walls.Left.Brush.Gradient.StartColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(255)))));
            this.GraphChart.Walls.Right.Brush.Color = System.Drawing.Color.FromArgb(((int)(((byte)(192)))), ((int)(((byte)(192)))), ((int)(((byte)(192)))));
            this.GraphChart.Walls.Right.Brush.Gradient.EndColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(0)))));
            this.GraphChart.Walls.Right.Brush.Gradient.MiddleColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
            this.GraphChart.Walls.Right.Brush.Gradient.SigmaFocus = 0F;
            this.GraphChart.Walls.Right.Brush.Gradient.SigmaScale = 0F;
            this.GraphChart.Walls.Right.Brush.Gradient.StartColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(255)))));
            this.GraphChart.UndoneZoom += new System.EventHandler(this.GraphChart_UndoneZoom);
            this.GraphChart.ClickBackground += new System.Windows.Forms.MouseEventHandler(this.GraphChart_ClickBackground);
            this.GraphChart.Zoomed += new System.EventHandler(this.GraphChart_Zoomed);
            // Form1
            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
            this.ClientSize = new System.Drawing.Size(839, 509);
            this.Controls.Add(this.GraphChart);
            this.Name = "Form1";
            this.Text = "Form1";
            this.Load += new System.EventHandler(this.Form1_Load);
            this.ResumeLayout(false);
        #endregion
        private Steema.TeeChart.TChart GraphChart;
The Form1.cs code :
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.Globalization;
        private Steema.TeeChart.Axis myCustomAxisInGrams = new Steema.TeeChart.Axis();
        private Steema.TeeChart.Axis myCustomAxisInLiters = new Steema.TeeChart.Axis();
        private Steema.TeeChart.Styles.Series myEndOfCycleEventsSerie = null;
            CultureInfo theCurrentCulture = null;
		    DateTimeFormatInfo theCurrentDateTimeFormatInfo = null;
            theCurrentCulture = CultureInfo.CurrentCulture;
            theCurrentDateTimeFormatInfo = theCurrentCulture.DateTimeFormat;
            string dateTimeFormat = theCurrentDateTimeFormatInfo.ShortDatePattern + " " + theCurrentDateTimeFormatInfo.LongTimePattern;
            // Create custom vertical axes
            myCustomAxisInGrams.Horizontal = false;
            myCustomAxisInGrams.Automatic = true;
            myCustomAxisInGrams.Title.Text = "(Grams)";
            myCustomAxisInGrams.Title.Angle = 90;
            myCustomAxisInGrams.RelativePosition = 0;
            myCustomAxisInGrams.Visible = false;
            myCustomAxisInGrams.Labels.ValueFormat = "#,##0.00";
            myCustomAxisInLiters.Horizontal = false;
            myCustomAxisInLiters.Automatic = true;
            myCustomAxisInLiters.Title.Text = "(Liters)";
            myCustomAxisInLiters.Title.Angle = 90;
            myCustomAxisInLiters.RelativePosition = 0;
            myCustomAxisInLiters.Visible = false;
            myCustomAxisInLiters.Chart = GraphChart.Chart;
            myCustomAxisInLiters.Labels.ValueFormat = "#,##0.00";
            GraphChart.Axes.Custom.Add(myCustomAxisInGrams);
            GraphChart.Axes.Custom.Add(myCustomAxisInLiters);
            // Bottom axe
            this.GraphChart.Axes.Bottom.Labels.DateTimeFormat = dateTimeFormat;
            this.myEndOfCycleEventsSerie = CreateOneEventSerie("End of cycle events", Steema.TeeChart.Styles.PointerStyles.Circle, System.Drawing.Color.Green, System.Drawing.Color.Yellow, 3, 3);
            this.myEndOfCycleEventsSerie.Active = true;
            GraphChart.Series.Add(this.myEndOfCycleEventsSerie);
            // Click event
            this.myEndOfCycleEventsSerie.Click += new System.Windows.Forms.MouseEventHandler(this.EndOfCycleEventsSerie_Click);
            // Define some liters values
            this.myEndOfCycleEventsSerie.CustomVertAxis = myCustomAxisInLiters;
            myCustomAxisInLiters.Visible = true;
            myCustomAxisInLiters.AxisPen.Color = Color.Black;
            myCustomAxisInLiters.Labels.Font.Color = Color.Black;
            myCustomAxisInLiters.Title.Font.Color = Color.Black;
            // Add points
            this.myEndOfCycleEventsSerie.Add(DateTime.Now - TimeSpan.FromMinutes(3), 10.0);
            this.myEndOfCycleEventsSerie.Add(DateTime.Now - TimeSpan.FromMinutes(2), 10.0);
            this.myEndOfCycleEventsSerie.Add(DateTime.Now - TimeSpan.FromMinutes(1), 10.0);
            // Set the axe to automatic to true
            this.myCustomAxisInGrams.Automatic = true;
            this.myCustomAxisInGrams.AdjustMaxMin();
            this.myCustomAxisInLiters.Automatic = true;
            this.myCustomAxisInLiters.AdjustMaxMin();
            GraphChart.Refresh();
        private void GraphChart_ClickBackground(object sender, MouseEventArgs e)
        private void GraphChart_UndoneZoom(object sender, EventArgs e)
        private void GraphChart_Zoomed(object sender, EventArgs e)
                // Set min / max for both the custom axes.
                this.myCustomAxisInGrams.SetMinMax(this.myCustomAxisInGrams.CalcPosPoint(GraphChart.Zoom.y1), this.myCustomAxisInGrams.CalcPosPoint(GraphChart.Zoom.y0));
                this.myCustomAxisInLiters.SetMinMax(this.myCustomAxisInLiters.CalcPosPoint(GraphChart.Zoom.y1), this.myCustomAxisInLiters.CalcPosPoint(GraphChart.Zoom.y0));
        private Steema.TeeChart.Styles.Series CreateOneEventSerie(string myTitle, Steema.TeeChart.Styles.PointerStyles myPointerStyle, System.Drawing.Color myPointerColor, System.Drawing.Color myPenColor, int vertSize, int horizSize)
            Steema.TeeChart.Styles.Points mySerie = new Steema.TeeChart.Styles.Points();
            mySerie.Title = myTitle;
            mySerie.Pointer.Style = myPointerStyle;
            mySerie.Pointer.Color = myPointerColor;
            mySerie.Pointer.VertSize = vertSize;
            mySerie.Pointer.HorizSize = horizSize;
            if (myPenColor != System.Drawing.Color.Empty)
                mySerie.Pointer.Pen.Width = 2;
                mySerie.Pointer.Pen.Color = myPenColor;
                mySerie.Pointer.Pen.Visible = true;
            // Set series type
            mySerie.XValues.DateTime = true;
            mySerie.YValues.DateTime = false;
            // Not visible by default
            mySerie.Visible = false;
            // Set the cursors on events
            // Return serie
            return mySerie;
        private void EndOfCycleEventsSerie_Click(object sender, System.Windows.Forms.MouseEventArgs e)
Post by Sandra » Thu Jun 18, 2009 10:07 am
Hello nico193,
We couldn't reproduce your issue with last version of TeeChartFor .Net (version 4) and this is the latest evaluation version available. Please could you say exactly with is your TeeChartFor .Net version use?
Also, in your code I have added lines in the Event Click, for checked that works. Please add this lines and check that works fine in your application:
        int n;//<---int that use in click event.
            // Bottom axe
            // Click event
            n = 0;//<--- This lines initialize int and is used in Click event;
            // Add points
            // Set series type
            // Return serie
            return mySerie;
            //Add this code for check that the click event works
           n += 1;
            GraphChart.Header.Visible = true;
            GraphChart.Header.Text = "Series clicked " + n.ToString() + " times";
nico193
Post by nico193 » Thu Jun 18, 2009 12:38 pm
Thanks for replying.
I've put a breakpoint in the Click event to see it's fired or not. But the message is more explicit, you're right.
About the Teechart version :
The TeeChart.dll version is 4.0.2009.16186
I'm working with Visual Studio 2005 SP1, with Windows XP SP3.
The click event is fired in VS 2003 with a previous version of Teechart.
Post by Yeray » Thu Jun 18, 2009 2:01 pm
Hi nico193,
Excuse us, we were doing the tests with the actual sources, not with the version available at the download area and we couldn't reproduce the problem because this is a bug recently fixed (TF02014214). So it should work fine with the next maintenance release.
