Creating and exporting chart to jpg at server side
SDG
Post by SDG » Mon Jun 15, 2009 11:20 am
I am trying to create chart class, exporting it to jpg and display at browser as JRE is not allowed to install at browser's system. But I am getting error while creating class itself. Please find the code and error message below.
source:
CreateGraph.java
public class CreateGraph extends HttpServlet {
private static final String CONTENT_TYPE = "text/html; charset=windows-1252";
public void init(ServletConfig config) throws ServletException{
super.init(config);
System.out.println(config.getServletName());
System.out.println(config.getInitParameterNames());
public void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException{
String var0show = "";
try
var0show = request.getParameter("showthis");
catch(Exception e)
e.printStackTrace();
MyChart mychart = new MyChart();
response.setContentType(CONTENT_TYPE);
PrintWriter out = response.getWriter();
out.println("<html>");
out.println("<head><title>Create Graph</title></head>");
out.println("<body>");
out.println("<p>Create Graph</p>");
out.println("</body></html>");
out.close();
MyChart.java
public class MyChart extends ChartPanel {
//public class MyChart extends SamplePanel {
private static long icurrentTimeMillis;
private static DateTime PrepareDateTime(){
if (icurrentTimeMillis == 0) {
icurrentTimeMillis = System.currentTimeMillis();
icurrentTimeMillis = icurrentTimeMillis + 1000;
return new DateTime(System.currentTimeMillis() + icurrentTimeMillis);
public MyChart() {
Line series1;
series1 = new Line(chart1.getChart());
series1.setColorEach(false);
series1.getMarks().setArrowLength(20);
series1.getMarks().setVisible(false);
series1.setDark3D(false);
try {
DateFormat formatter = new SimpleDateFormat("SSS");
long cTM = System.currentTimeMillis() + 9 * 60 * 60 * 1000;
Random random = new Random(1000);
for (int iIndex = 0; iIndex < 1000; iIndex++) {
Date date = formatter.parse(String.valueOf(cTM));
cTM = cTM + 1000;
//System.out.println(date + " " + date.getTime());
Timestamp st = new Timestamp(cTM);
java.sql.Timestamp timeStampDate = new Timestamp(date.getTime());
//System.out.println(st.getTime() + " " + timeStampDate.getTime());
DateTime dt = new DateTime(cTM);
series1.add(dt, random.nextInt());
} catch (Exception e) {
System.out.println(e);
chart1.getAxes().getBottom().getLabels().setAngle(90);
chart1.getAxes().getBottom().getLabels().setDateTimeFormat("hh:mm:ss.SSS");
this.setBackground(Color.YELLOW);
validate();
repaint();
Error is:
java.lang.NoClassDefFoundError: com/steema/teechart/IBaseChart
at CreateGraph.doGet(CreateGraph.java:25)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:263)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:584)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Unknown Source)
Thanks in advance,
Best,
Veeranna Ronad.
Re: Creating and exporting chart to jpg at server side
Post by Marc » Tue Jun 16, 2009 7:34 am
Hello Veeranna,
There's no apparent problem with the code though I don't see how the imports are setup. Please check that you have imports linked to your Chart classes. You could add a direct import to com.steema.teechart.IBaseChart.
SDG
Post by SDG » Tue Jun 16, 2009 10:14 am
Dear Marc,
I added import com.steema.teechart.IBaseChart; to CreateGraph.java source. Even after this I get error. Please find the attached source.
Error;
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Servlet execution threw an exception
root cause
com.CreateGraph.doGet(CreateGraph.java:27)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.14 logs.
Kindly advice me.
Thanks in advance,
Best,
Veeranna Ronad.
src.7z
Project where TeeChart instance is created.
(7.95 KiB) Downloaded 1350 times
Post by Marc » Thu Jun 18, 2009 3:04 pm
Hello Veeranna,
To check your example, I took your code units and added them to a new web project in Netbeans. To simplify any possible pathing problems I put the units from the MyServlet folder in the same folder as the CreateGraph.java file and removed all 'package xxxx' lines from the beginning of each unit. I added the call to CreateGraph to the project's servlet list.
A library path to TeeChart.Swing.jar was added to the project library path.
To check that the CreateGraph is correctly interacting with TeeChart itself I modded a couple of the lines in CreateGraph to read then modify the Chart header.
//test lines
out.println("<p>Old Header: "+mychart.chart1.getChart().getHeader().getText()+"</p>");
mychart.chart1.getChart().getHeader().setText("My test TeeChart header");
out.println("<p>New Header: "+mychart.chart1.getChart().getHeader().getText()+"</p>");
out.close();
The project was deployed from the IDE and ran successfully.
Please check your setup against these steps. If they don't clarify any possible causes of the problem in your installation then we'll need to compare details of project setup, etc.
