How To change or Remove the info box
Rabbit
Post by Rabbit » Wed Jul 01, 2009 5:38 am
Iam using BarJoin,
I want to keep the numbers on each bar as in the attached picture.
Also, I want to control the information title as in the red cycle. without effectig the number yellow box on the top of each bar.
Can you help me plz?
Thanks!
Re: How To change or Remove the info box
Post by Sandra » Wed Jul 01, 2009 8:43 am
Hello Rabbit,
I make a simple example. You can use a similar code in your application for control text in the legend.
 Steema.TeeChart.Styles.BarJoin barjoin;
            barjoin = new Steema.TeeChart.Styles.BarJoin(tChart1.Chart);
            barjoin.Add(100, 25, "value1");
            barjoin.Add(125, 35, "value2");
            barjoin.Marks.Style = Steema.TeeChart.Styles.MarksStyles.Value;
I hope that will helps.
Rabbit
Post by Rabbit » Thu Jul 02, 2009 3:30 pm
Thanks!
